I try to turn on the wifi, but nothing happens. The box goes gray, and then resets. Yes, my phone is rooted. Any help?
Are you on Metro or Cricket?
Metro.
I had that happen to me and after I did a hard reset it all worked fine
LOL I was just sayingOne thing at a time, honey! He may have to resort to the reset but we hope not!
Download Cache Mate or Cache Cleaner NG from the Market and clear your cache. Also clear your call log and text message log. Make sure wifi is checked in your settings and try again.
Have you looked at
androidforums.com/huawei-ascend/249341-i-disabled-wifi-now-cant-re-enable.html
Not trying to be rude or anything, but that link doesn't have a solution...
No problem. If you installed a tether app it does.
yeah, i do have one. So uninstalling the tether app will fix the wifi problem?
Thank you so much! Uninstalling the tether app did work.![]()
LOLI think you can still keep the tether app, and when you want to use wifi, just disable the tether app
You copied meLOL JK
