Hey guys, I'm new to all this stuff so go easy on me lol. I have done A LOT of reading about this problem but I can't get any of those suggestions to work. The WiFi on my EVO will stay on when the screen is shut off (the settings in CM7 have been set so that it should turn off with the screen). I am running the latest nightly of CM7, I have tried numerous kernels (currently using the latest Tiamat), I have used CPU Spy and Better Battery Stats (which is a little difficult for me to understand) and can't seem to isolate anything that would keep the WiFi on when the screen is off. I have wiped the cache, Dalvik cache, battery stats, you name it, it's been wiped... Then I installed CM7 without the GApps and the WiFi still remains on when the screen is off. I have tried changing the policy in the "WiFi sleep policy" settings to "Never" and "Never when plugged in" and still have the same problem. Some of the posts that I have read about this problem pointed towards a rogue app or an app that's using the WiFi while the screen is turned off but (perhaps my lack of intelligence in regards to Better Battery Stats is the culprit) I can't seem to find anything that would be causing the problem. I would appreciate any help that I can get! Thanks guys.
