Wiimote connection finally a reality for HTC/Sense
dr g
This will probably mean absolutely nothing to most, but I for one have been waiting since the OG Evo for the ability to connect to a Wiimote via bluetooth. We can finally do it with the Evo LTE!
This is the app I'm using:
https://play.google.com/store/apps/details?id=com.ccpcreations.android.WiiUseAndroid&hl=en
Takes some configuration and it's a little bit unweildy (need to select the Wiimote IME) but it does work fine for the emulator I have been waiting to use (Gensoid). Now to get a MHL adaptor ...
I see that there are other apps, may have to give some a try and see if they are less clunky.
