Help will not recognize sdcard/update.zip on sd card
roycal5
What did i do wrong. With my reboot i have put the update on my computer and transferred it to the sd card and renamed it update.zip but on the reboot it is not being recognized when i apply the sd card: update.zip on my phone?
please help
please help
If you typed update.zip then it becomes. update.zip.zip. Just type in "update".
HTH
+1
Depending on your computer's settings for file extentions, filename update.zip may become update.zip.zip because it reapplies the .zip after the fact.
As a point of reference, on Windows the setting in question is at My Computer > Tools > Folder Options > View > Hide extensions for known file types
If checked, it adds the extra .zip, if unchecked it does not. (I think I have that last part right) :D
