Petrah
Psychotic Female
major update like this will not trigger automatic download as it could cost huge data fee if forgotten to set download over wifi only
I don't think there has ever been an automatic download for an Android OS OTA update.
what is automatic update for? just minor patches?I don't think there has ever been an automatic download for an Android OS OTA update.
so if i check automatic update, what does it doThere is no automatic update for OTA. Not even for minor patches. The end user must manually initiate the download in order to install the update.
which devices? not samsung?Some devices automatically download the OTA and prompt the user for install
like i said, i don't think this is carrier related. all updates pushed out by samsung have to be approved by carrier, bloatware added, then sent back to samsung. then the phones get their update from samsungAh, didn't realize that. None of the devices I've had have ever done that. I always get a notification that encourages me to enable WiFi for a stable download.
I'm not sure anyone would have such a list. You could try asking around in different device forums, a Google search, or ask in your carrier specific forum (which may give you better results for answers) where others with the same carrier can better assist you.
thanks. so this update will NOT download automatically even if i have the automatic update checked?Assuming that your model is the SGH-i337M for Canada, see #1.2 of 18 Galaxy S4 models - know yours?, which is very similar to the International, GT-i9505, there should be in...
Settings > More > About device > Software update...
the following screen...
This allows you to check for updates manually or, if checked, to automatically update and, lastly, to only update automatically over Wi-Fi.
The latest update for the SGH-i337M takes it from Android 4.2.2 to Android 4.3 and adds several bug fixes and improvements, including...
OpenGL 3.0 Support
GALAXY GEAR Support
TRIM Support (Makes the device much faster)
ANT+ Support
Samsung KNOX Implementation (KNOX bootloader and dedicated application)
Samsung Wallet comes pre-loaded
Improved RAM management
Improved Display colour reproduction (Display looks much sharper than before)
Improved TouchWiz Launcher (Much less launcher redraws and less lag)
New Samsung Keyboard
New Samsung Browser (Full screen by default, new tab interface and more)
New Reading Mode (Optimises display for reading, used by only a few specific applications)
New Camera firmware
Minor UI tweaks (Contacts app, Flashlight Widget, dialog boxes etc)
i have box #2 CHECKED, so that means it will AUTOMATICALLY UPDATEBox #1 = Manual check
Box #2 = Automatic update over either data or Wi-Fi
Box #3 = Automatic update only over Wi-Fi
