Help Will Removing Battery While Phone On Cause Damage?
Johnny Cakes
Can I do any damage by just pulling the battery while the phone is on? With the number of times I have to change the battery to keep the phone going, its just easier than going through the effort to power down.
Not usually. You might find that when you reboot you don't have all your text messages from the last hour and missed calls suddenly become new again, but other than that you should be fine.
