Root [WIP] [KERNEL] ZVE Overclock Kernel
Yes.. Just flash as normal.. Missing files have been added :) Only thing I've noticed is the OC doesn't stick after reboot.. Otherwise its stable.. been runnin it on number 2 3 for about a week or so now with no issues and haven't heard anything bad from anyone.. prob about as stable as its gonna get..
Good job, Travioso. I've been running it over GS3 and it's pretty stable. I have the phone at 1900 and hasnt rebooted.
I'll post back if there are any issues with this kernel/rom.
** The OC sticks after reboot for me. I'm currently using Smartass2. **
What are you using to OC with?
Same here.. The slider sticks at wherever i put it but the actual clock speed is at 1024 and ondemand vs smartassv2 and 1200 which it should be. Does Yours say whatever you have it oc'd to after reboot?
Edit: some governors will stick (for instance powersave and on demand) and also apply the clock speed at boot.. Others won't..
Yes, the clock says 1800.
Just noticed the governor switched to OnDemand.
