blaze420916
Android Expert
I want a motion now..lol..must play must play...flash flash flash...I'm an addict.
Aaron when I get my n4 hooked up I'll send you my motion
How this ROM coming along, anyone know?
New build will be posted tomorrow with all of the current base fixes + a few bug fixes.
Sorry going to have to delay this for a few days unless any of you would like to help fix sms. Sms will not work, my sms fix method doesn't work with files from pg's framework.jar I forget what rom and device I used last time.
But just for the heads up, once I get this rom too 100% and when someone fixes the 1080p this will be my last work on this device most likely. I may or may not update the other ports.
I'll try to fix..I know a little. Link me if you want...I've dealt with that once..just gotta remember the fix I used
I fixed this before. I just don't remember what device and miui version on that device I used. Or did I use one of pg's builds? I don't remember. I tried using the current pg build for the sms fix but no go. I get a bootloop. But now that I think about it I may know why it does that.Now to work on sms.
Edit: SMS FIXED!!!!!!!!!
It most likely won't work. But you can try :/i will try to port this from the GS3 instead of the optimus lte2
It's in the framework.jar.Hey have you tried the apns-conf.xml file in "etc" folder. I think that has something to do with sms?
Edit: mind sending me what you have so far? I feel like trying some things to fix sms. I have a couple ideas that i wanna try.
I fixed sms
Sorry to all that messaged me offering to help. I went all geek mode and did over 30 framework tests. Pretty much spent the entire day attempting to fix sms and get frustrated.
I forget what files I replaced for it to fix because I gave up and went to sleep. When I woke up I saw that I forgot to flash my lastest framework jar. And bam that one worked
Build will be up tomorrow morning. :cheers:
Text sent to myself.
I fixed sms
I fixed sms
Sorry guys I passed out from being up all night. OP updated!
I'm still working on a few bugs but it should still work be sure to read the instructions(And everything in the op)
It's not daily driver martial.(video recording bug, but I may know how to fix) But it still looks and feels amazing. I'm using it as my daily.. Until... Finish the "Other" Miui I'm going to release maybe next week
MIUI 5 status = Boots(most apps need resizing)
i got a status 7 error set_perm:some changes failed
