Craptorman
DISCLAIMER: Flash at YOUR OWN RISK!!! By flashing this you understand that that I am not liable for any or all consequences of using this ROM. If you don't know what you're doing, DON'T TRY IT. Use at your own risk! Please read everything before asking questions that may have already been answered.
This is a WIP. NOT ALL FEATURES ARE WORKING. I am NOT an experienced developer so I may not be able to answer all questions. I am posting what I have so far in hopes of others jumping on and helping. Since I don't have a Marquee I can't really test this. It's at a state where it builds and should boot.
THIS WAS BUILT WITH PROPRIETARY FILES PROVIDED BY lMonsterl which has BOOST. (Correct me if I'm wrong)
My repo is located here
You'll need to download the zip and extract it to /android/system/device/lge/LS855/
HOW TO:
For a how-to on building see knzo's post here
Before building, but after step 3 in knzo's how-to, you'll need to do a couple more things. (You can skip step 4, this is only if you're building P970)
1.First you need to copy the proprietary files from the device. Connect the device to the computer and ensure that ADB is working properly and then run the following.
Code:
cd ~/android/system/device/lge/LS855/
./extract-files.sh
3. You'll need to add "add_lunch_combo cyanogen_LS855-eng" to the "vendor/cyanogen/vendorsetup.sh" file.
4. Now do step 5 in knzo's post and change "p970" to "LS855"
5. It should now be building.
6. Troubleshoot any errors and repeat, and repeat, and repeat.
CREDITS:
Thanks to playfulgod for providing CWM Recovery, helpful tips and script files examples).
-CM7 Crew, koush, Paranous, TryingToRoot, lMonsterl, rockodev, dsixda
What is this ROM?
-CM7 built from source
What's Working:
-Audio
-Wifi
-Bluetooth (need someone to verify BT headset works) - fixed 5/15
-Camera (G-Button may not work) - fixed 5/15
-Video Playback (check if there is audio or not) - fixed 5/15
- 3G is sporadic - 10/27
TO INSTALL:
-MAKE A BACKUP
-You MUST, do a Factory Reset prior to flashing.
-Download or copy the zip to the root of your sdcard
-Reboot into CWM Recovery
-Wipe cache partition & Dalvik
-"Install zip from Sd"
-Select zip and hit "yes"
-I've been wiping cache partition & Dalvik
-Reboot!
DOWNLOAD:
10/27/12 - Boost version, Sprint version
Like what u see? Hit "Thanks"
