Root [WIPE] LD-Easy_Wipe(s)
LDrifta
No Stranger 2 Danger
READ & FLASH CAREFULLY!!!!!!
Information:
~LD-Easy_Wipe_Quick = simple CWM flashable script to wipe data, cache & dalvik cache
A.K.A. The ROOT users 'factory reset'
(can be used to restore rom default settings but you will lose ANYTHING that came pre-installed to data)
~LD-Easy_Wipe_Full = simple CWM flashable script to wipe SYSTEM, data, cache & dalvik cache
(ONLY use this before flashing a NEW rom, it will format your 'system' leaving you with NO rom.)
it's just a little treat to make flashing that much more noob friendly/easier..
these are both designed to flash before a new rom, just so you dont have to manually do it every time.. but still RECCOMENDED you do your wipes manually from time to time..
YOU WILL LOSE YOUR DATA IF YOU FLASH THESE!!!
Download Links:
-Easy_Wipe_Quick - DATA & Cache ONLY
-Easy_Wipe_Full - DATA, SYSTEM & Cache
Enjoy!, Be sure to read all warnings above, I am not responsible for any damage done to your device :D
Happy Flashing!!!
you're making ppl so lazy! lol
make em learn at least how to select factory reset > confirm, and then goto advanced > wipe dalvik cache > confirm > back > reboot system. ;)
we cant do everything for em, they need to learn these things if they are going to be modding their devices. ;)
lol
lol
haha yeah ur right.. but just figured why the hell not got plenty of time to waste while this sh*t compiles haha
The full wipe is GREAT to use before installing/testing out a new ROM so I wanted to bump this back up so that ppl know its here ;) "REMEMBER YOU WILL LOSE ALL DATA IF YOU USE THESE", so dont be suprised when you have to fix your settings again.
