TVCCS
Okay...here's the result of my efforts on tethering tonight...the news is mostly good, I think.
Wired - I noticed Mobile Stream EasyTether has an LG Ally driver on their Web site, and says all LG phones need this added driver (much like the Intercept needs an added Samsung driver). I found a post elsewhere where a guy in Greece used the same driver on his Optimus GT540 to get PDANet to work last year. I downloaded and installed the LG Ally driver - it took several minutes for the driver to install, but it did. I then rebooted both the system and the phone, and when the system came back up, it installed additional drivers including the ADB connect for a minute or two, and then finished. At that point I connected via EasyTether, and although the Network & Sharing Center (Vista 32) indicated I had a Local connection only, the system connected to the Internet. I hit the Speakeasy server in Chicago (about 300 miles away) and got the following results from a fairly weak 2-3 bar 3G connection.
Last Result:
Download Speed: 639 kbps (79.9 KB/sec transfer rate)
Upload Speed: 160 kbps (20 KB/sec transfer rate)
How to tether Android - EasyTether. Android tethering for Mac OS X, Ubuntu, PS3, XBox, Wii, Windows
As far as wireless tethering/HotSpot connections, there are a number of programs on the Market that allow users to make the HotSpot Settings visible and enabled. Linux people have figured out settings on their own. It works, and others are reporting the same result elsewhere. No rooting required, although there is discussion this could be disabled in a future software update from Sprint/VM. There are numerous threads on this across Android and other forums and sites.
Here is one example:
LG Optimus S Tethering - LG Cell Phones Blog
And here's the direct link to get Quick Settings from the Android Market:
https://market.android.com/details?id=com.bwx.bequick
And since this seems to be such a popular thread...here's are two YouTube videos on finding and installing Quick Settings on an Optimus V.
http://www.youtube.com/watch?v=Dhmsv9eV3lU
http://www.youtube.com/watch?v=qimo5z8FLyI
Last Result:
