Root Wireless Tether as access point
iowabowtech
root@android:/ #
I know there was another thread on this topic that linked to the XDA forum but that thread is more about loading a specific kernel to enable AP Tether. I like Hydra's new kernels and you can do the same thing with them as well.
I attempted to install the newest version of Wireless Tether from the market but it did not allow AP mode. So I found it's necessary, as verified elsewhere, to install the (wireless_tether_2_0_5-pre3.apk) version. Once I did this and added the bin file, it worked great. WPA2 security is also included in this version.
So to make it easy, I just created a zip that's already called Android.tether and has the required .apk and .bin already inside for AP Tether. This is not supported with the stock kernel, check to see if your kernel of choice supports it if you are in question. I can for sure verify the Hydra OCUV 1.113 ghz v0.8 kernels.
RapidShare: 1-CLICK Web hosting - Easy Filehosting
Its the same bin file as the original one from root right? I didn't change anything in the android.tether folder and got it working with the 1.15 oc v.8 kernel.
