Root Wireless tether hates me....
richb82
Just installed Win7 on my nieces laptop today. I had EasyTether running fine on it, so I switched to Wireless Tether, and I got horrible results. And now I can't even get EasyTether to work lol. Anyways, wtf is going on here with my Wireless Tether?!?! I have the phone literally within 2 feet of the laptop, and signal level is around -78db. And when I surf from the phone itself, it's snappy and quick. Anything in particular I should check here?
Code:
C:\Users\Kayla>ping google.com -t
Pinging google.com [72.14.204.104] with 32 bytes of data:
Reply from 72.14.204.104: bytes=32 time=1447ms TTL=50
Request timed out.
Request timed out.
Reply from 72.14.204.104: bytes=32 time=147ms TTL=50
Reply from 72.14.204.104: bytes=32 time=111ms TTL=50
Request timed out.
Reply from 72.14.204.104: bytes=32 time=105ms TTL=50
Request timed out.
Request timed out.
Reply from 72.14.204.104: bytes=32 time=573ms TTL=50
Request timed out.
Reply from 72.14.204.104: bytes=32 time=107ms TTL=50
Request timed out.
Reply from 72.14.204.104: bytes=32 time=174ms TTL=50
Reply from 72.14.204.104: bytes=32 time=103ms TTL=50
Request timed out.
Reply from 72.14.204.104: bytes=32 time=134ms TTL=50
Reply from 72.14.204.104: bytes=32 time=82ms TTL=50
Request timed out.
Reply from 72.14.204.104: bytes=32 time=1012ms TTL=50
Request timed out.
Reply from 72.14.204.104: bytes=32 time=161ms TTL=50
Request timed out.
Reply from 72.14.204.104: bytes=32 time=125ms TTL=50
Reply from 72.14.204.104: bytes=32 time=110ms TTL=50
Request timed out.
Request timed out.
Reply from 72.14.204.104: bytes=32 time=100ms TTL=50
Request timed out.
Request timed out.
Request timed out.
Reply from 72.14.204.104: bytes=32 time=2140ms TTL=50
Reply from 72.14.204.104: bytes=32 time=927ms TTL=50
Request timed out.
Reply from 72.14.204.104: bytes=32 time=586ms TTL=50
Ping statistics for 72.14.204.104:
    Packets: Sent = 37, Received = 20, Lost = 17 (45% loss),
Approximate round trip times in milli-seconds:
    Minimum = 82ms, Maximum = 2140ms, Average = 419ms
Code:
C:\Users\Kayla>tracert google.com
Tracing route to google.com [72.14.204.104]
over a maximum of 30 hops:
  1    49 ms     *       10 ms  192.168.2.254
  2     *      497 ms    79 ms  64.sub-66-174-121.myvzw.com [66.174.121.64]
  3     *        *        *     Request timed out.
  4  2380 ms     *        *     177.sub-69-83-15.myvzw.com [69.83.15.177]
  5  1554 ms  1570 ms     *     18.sub-69-83-14.myvzw.com [69.83.14.18]
  6  1524 ms  1690 ms  1990 ms  132.sub-66-174-18.myvzw.com [66.174.18.132]
  7     *     1586 ms     *     131.sub-66-174-18.myvzw.com [66.174.18.131]
  8     *     1112 ms  1214 ms  253.sub-69-83-3.myvzw.com [69.83.3.253]
  9     *        *     1499 ms  ge5-0-3d0.cir1.nyc-ny.us.xo.net [209.220.16.13]
 10  1513 ms  1899 ms     *     209.220.16.110.ptr.us.xo.net [209.220.16.110]
 11     *     2172 ms  2033 ms  209.85.252.215
 12  2263 ms     *     2237 ms  209.85.249.11
 13  1832 ms     *     1124 ms  66.249.94.46
 14     *     1183 ms  1314 ms  iad04s01-in-f104.1e100.net [72.14.204.104]
Trace complete.
Try changing the channels on your wifi. Get an app called wifi analyser to see if there are other wifis in the area on or near the same channel.
That was my problem, tried a million different versions of the wifi tether, and turns out, my signal was just getting stepped on.
