Currently using DamageControl 2.08 and Can't get Wireless tether to work. I tried a bunch of different versions under the Cupcake/Donut option cause some said it worked.
If wifi tether came preinstalled on your ROM then uninstall it. If the option is not listed to uninstall when you go into applications-manage applications then do this.
Manually remove the wifi tether apk from /system/app
install either version 2.0.2 or 2.0.5pre and then uninstall it.
now when you install 2.0.2 or 2.0.5pre again it will reinstall all the binaries and it should work.
This is what I had to do on purehero which is based off DC.
