EVO with 2.1 rooted with unrevoked3. Installed Wireless tether which is working well. Here is my issue
So...
ipad on work wifi = 12-13 Mbps
Evo on work wifi = 9 Mbps
ipad on Evo = 4-6 Mbps
So you are not understanding why the iPad isn't getting higher speeds when tethered to the Evo? And the Evo is on the 4G network as you mentioned...
Here's the deal, the Evo isn't receiving data that quickly when on the cellular network. Your work wifi may be pushing 9 or 12-13 Mbps, but that doesn't have any correlation to the sprint network. I hear 4-6 Mbps is pretty darn good.
I think you misrepresented the various speeds Wiltok cited. The O.P. states that his tower to device (4G) speed is 4-6 mbps. The problem is that the Ipad's network connection through the Evo's 4G only yields 1.2 mbps. Additionally, the Evo loses roughly 30% of his workplace Wi-fi bandwidth.
I'm unfamiliar with the Ipad so I don't know what, if any, anti-virus or firewalls may be on board. I know from experience that Sprint 4G Hotspot Wi-fi tether running 2.1, and AVG don't play well together. I could be getting 8+ mbps tower to device and the laptop would crap out at 1.2 mbps. In desperation for a fix, I prepared to run Trend Micro House Call and uninstalled the AVG. I went to the T.M. site to start the download and thought the laptop was a bit snappier. I ran a speed test and shazam! Problem solved... sort of. The Evo and Hotspot will eat alot of bandwidth (40%-50%). PdaNet will eat considerably less, and Easytether will eat still less yet.
So, are you saying that using your WiFi hot spot will give you a slower download rate than wired tethering? ...
