Root Wireless Tether not running?
Knitewulf
Whenever I run wireless tether it runs for like 2 seconds and then 0 kbps for the rest of the time. Is there any way to fix this?
Running 2.2 and the current version of lithium mod.
Please and thanks.
What do you mean when you say "it runs"?
Are you able to achieve a connection with other devices?
Agreed, a different kernel could help. For the short period that it initially runs, are you able to receive data on the tethered device?
Before you change kernels, I would play around with the SSID and signal channel if you haven't already.
