stonehenge1861
Member
Has anyone tried it yet? I noticed then when i turn it on it pops up in the notification bar that the tethering is on. Anyone else noticed?
One thing I have noticed when I was renaming the bloat is that the 3G Mobile Hotspot that use to be named Mynet.apk is not there anymore, however I still have 3G Mobile Hotspot on my phone and I could not find the apk for it. I wonder if they made a change in this build to try and block this?
Has anyone tried using the built in tethering and mobile hotspot option in the Wireless settings menu? I was afraid to try, in case I accidentally activated a Verizon hotspot plan or something.
Wireless Tether is working fine for me, I just tried it, had a friend try to connect and he connected without a problem.
Did a blur notification about the use of tethering come up? Did you change any Wireless Tether settings?
I had an icon in my notification bar that wanted me to configure the tether or hotspot. I could not get it to work with a password enabled but once I disabled the password (in security) it worked fine.
I didn't want to use that patch just yet. I actually won't need the hotspot for about another week and a half. If I can stay away from the actual app, it would be better (and safer).
has anyone tried to uninstall the stock hotspot app yet....or is it still an issue with some hidden programing....was gonna flash, but no hotspot = no way.
