Root wireless tether wont work on newest 2.2 leak
I am still having issues with mine. i have the files loaded into the directory but the program doesnt load the bin file. this is a screenshot of my log. any help?
thanks all :)
i got the same error with the same set up...then i was able to get a connection if I turned off tether and then started it back again. sometimes i would have to do this a couple times.
I never had this problem until I updated to the newer radio file.
EDIT: I also put the android.tether file back on my SD even though it has been stated many times that you do not need it.
