I downloaded version 2.0.5 pre8 and it's working perfectly with Froyo. I had problems with the earlier ones.
wireless_tether_2_0_5-pre8.apk - android-wifi-tether - Wireless Tether for Root Users 2.0.5-pre8 *** EXPERIMENTAL *** - Project Hosting on Google Code
I have 2.0.5 pre7 and it works like it used to...
thats what i have. i installed it on the root of my sd and then i installed it using astro. it worked very well until i updated the leak to the 8/26 leak with the bloatware removed. now it won't work. when i go into astro and try to delete wireless tether in order to reinstall it to give it a try it says its unable to uninstall. i'm kind of confused as to how to get this to work.I downloaded version 2.0.5 pre8 and it's working perfectly with Froyo. I had problems with the earlier ones.
this worked for me running skyraider 3.0 with a 2.15 radioI downloaded version 2.0.5 pre8 and it's working perfectly with Froyo. I had problems with the earlier ones.
got it to work. i never had the android.tether file or the .bin file before. i just followed the guide and put both the apk and .bin file in a folder named android.tether on my sd card and from astro i installed the apk and it works like a charm. i appreciate your help!
actually i just tried to connect my laptop, and it will connect but i have no internet connection? i clock on google chrome and it opens the page with the normal error encountered when there is no internet connection. this is starting to irritate me haha...so laaaame. any suggestions?
so i lied...its working now...i don't get it. sometimes it works and others it doesn't..guess i will just keep effing with it. thanks a lot for your help!
and how do i go about installing this kernel you speak of? im super new to this whole rooting thing and i am slowly learning. it's been pretty fun so far!
I am still having issues with mine. i have the files loaded into the directory but the program doesnt load the bin file. this is a screenshot of my log. any help?
Note to above - you should use pre8, not pre7.
Anyway, using the newest "pre" build should result in success. I was had no problems running it on the 2.2 leak, without any special setup required.
