Wireless TV adapter
pmhoppe
I'd like to view my Skyrocket screen on my TV wirelessly using the Wi-Fi Direct feature. Does anyone know of a Wi-Fi Direct enabled receiver/converter that has composite video out for my older model TV.
You could use something, like mirrorOP software to stream signal on mctivia access point HDMI port, then use HDMI-to-composite converter.
Or you could waiting for xbounds:
http://www.youtube.com/watch?v=ILHEUWzZTOw
But you still need a HDMI-to-composite converter.
Or you could use adapter from your phone to HDMI, then use HDMI-to-HDMI wireless kit:
http://www.youtube.com/watch?v=7FXCbSJ4egY
But one more time, you still need a HDMI-to-composite converter.
You could use Peerless HDFlow:
http://www.youtube.com/watch?v=GZH10z-Lf0k
It's very powerfull, and has an internal HDMI-to-composite converter, but this kit alredy does not mobile and very pricey.
The converters that work are not cheap at all. I have not experimented much with wifi direct... but many cable boxes/satellite boxes can be set up to see it if you have a router.
Again on the HDMI converters.....not cheap at all. You would be better off buying a cheap 22"-32" TV IMO
Yes, you right, HDMI extenders are very expensive.
But it could deliver all content from screen to TV in real time, not just share media, as in DLNA...
indeed, trust me I agree, as I have had that ability on all of my android phones
but the point still stands...it would be the same price to buy a cheap TV with hdmi inputs :p
