Help Won't download.
aaronstrong
I try to install an app from the market and instead of downloading a orange rectangle with a exclamation mark appears. Click on it and says awaiting wifi connection. Is there a setting or something that can change this. Currently running .595. Thanks
What app is it?
OP, is it giving you any other kind of error code (aside from the wifi message)? You can also read through the thread in my signature and se if that helps.
