Root Working Edited Cpu Fix File
Squiggz
For the sake of making things easier to do, Ive copied my init.qcom.post_boot.sh file to share. Its been edited and is working on Black Plague 1.2. This is a WORKING cpu fix.
I am not liable for any adverse effects that may happen to your device. Use at your own risk.
Install:
Download
Move to SD
Using a file explorer, delete init.qcom.post_boot.sh file found in system/etc/
Replace with this file
Enjoy setting cpu clock speeds
http://db.tt/VW6ebwMR
Ok for some reason its working on my ohone now. AFter so many different ones i used. THe ones that came with the rom and the one that draconus did.
This one is working.
Is there a difference between not having the file and having this file?? Because i deleted the file it was with and they stuck.;)
Nothing major. I had it running with it del since B.O. came out, and when B.P. came out i had it del too with no issues. I just tried this to see if it would work because I was on lunch and tried it.
It does work, but IMHO if del works for you too then you are ok.
My opinion.
geez, when I asked what this one said, I didn't realize it showed it when you clicked the download link. I just thought it was going to be a zip. So, this is what I already have mine set as. I did read it correctly and the only thing added was the 2 lines with 1800000 cpu0 and cpu1 scaling_max_freq, correct? There isn't anything new that I overlooked?
Nothing new. Some people have had issues where the fix wouldn't work for whatever reason so, I made a copy of mine to share. I've tested it on a couple of Connect devices and it works. Same fix but works.
What he said O_O.... haha this one really is the only one that sticks for me as well. THANK YOU :D much appreciated
Installed it on my wife's phone, works like a charm.
Using the Black Plague 1.2 and there are no more issues with the CPU speeds changing at will.
Will recommend to many...
It might have been my phone, but after installing this on bp 1.2 my battery would go as high as 125 degrees. I had it under clocked at 900. On idle it wouldn't go lower than 105. It did work for me but it just caused my phone to heat up to much. Thanks anyway.
