barefooteagle
Me too, Me too. I will test...
https://sites.google.com/site/pncsoftware/
I made a site for the app. It's very basic but will have the apk. available for download when it's time.
Speaking of, it is nearly time. I just added in an authorization system so I can control who tests it. It will not function without authorization and will require internet access on the phone to validate after opening the app. (intended for BETA use only). It does store the last name entered so it's 2 clicks to get it to work after first use(auth button, and on button).
TODO: Add disclaimer, Add LED off on close using back button. I need the app to stay running during the on phase so it can properly turn off the LED.
Any other devs. out there got a good template disclaimer? I need to protect myself here.
Furthermore: If I give you a username to test this app. and any damages occur to the camera LED, it's lifespan, or the phone, etc., I am not responsible. There has been no testing on the short or long term effects of a camera application on the ZTE Warp or any other device it is run on.
Cool Idea but ZTE Warp has a flashlight glitch.
Open up camera, turn on flash, take a picture but hit the home screen when the camera square on the screen goes green and the flash will stay on... hit power once to turn off...
did 3 of the 5 minute intervals and it works like a charm
excellent work blackboltOkay so just tested the appdid 3 of the 5 minute intervals and it works like a charm
Is the App just a On screen light as opposed to a true flash light that uses the cameras flash,That is the impression i get from the site https://sites.google.com/site/pncsoftware/
ApolloStar2109 does this app effect your camera in any way. i have not installed it i was just wondering.
Blackbolt22 thank you very much for taking the time to make this app. Also, thanks for not getting up set with my lack of patients. i felt like a 5 year old on x-mas waiting to open presents when i first read this post.
such as Blackbolt22 will not be held responsible for any damages and such so i accepted the terms entered my username and testes the camera at 1 minute interval worked like a charm closed the app and reopened to make sure my username was saved and it was
tested at 2 minute interval worked perfectly closed reopened same thing username was saved 3 minute interval worked fine at this point any damage would become clear as my LED would start to burn out and it was still bright as it was before i tested so that cleared up i tested at 4 minutes same thing worked perfectly then i tested at 5 no problems what so ever and no damages
Can you clarify this question about the app affecting the camera?
It doesnt affect the camera at all![]()
i saw your previous post i was just answering his question what rom are you using?
How does one get to beta test this app?
