Bit of a strange question, but does anyone find that their phone is much slower/laggy with this battery? Not sure if it's a placebo, but when I'm on the stock battery my phone is lightning fast, but I put the ZL in and my phone lags like crazy : confused:
	My GPS has been having a lot of connection problems lately. Not sure if they were caused by the battery.
I just received a new battery since my old one seemed defective can some one please help me out I know that I need to do a 12hr 6times charge cycle but should I do it with the phone on or off? And I'm guessing I shouldn't use the phone at all during the charge?
The 12 hour charge only needs to be done once. Then the do a normal charge/discharge cycle 6 times. Let it drain to 1-2% then recharge. That info came directly from Joey at ZeroLemon. He didn't say whether the phone should be on or off. My thinking is that since you're not calibrating the battery but rather the phone to realize there is a larger capacity battery in it, the phone should be on.
I've never charged this battery with my phone off and I always get 2 to 2 1/2 days battery life with 18-24 hours of screen on, depending on what apps I'm using. I do let the battery continue to charge long after it hits 100% because I've found that if I unplug it too soon the battery percentage drops like a stone. I believe the battery isn't actually at 100% when the phone thinks it is. Whatever the reason, charging the phone for an hour or two after it hits 100% works well. Then it usually takes at least an hour to drop to 99% while using my phone.
My only question is, Why doesn't Zerolemon offer a "Pre-Conditioned" battery? One where they've done all the work ahead of time. They've done the first initial 12hr charge, and They've done the 4 to 6 charge/drain cycles. Cause I would have been Much more interrested in buying that.
Because the point to doing that yourself is so that your phone will recognize that it has a bigger battery in it. If all u had to do was install and charge normally then the battery percent would probably be off and the phone wouldn't recognize there's a bigger battery in it there for not giving you full potential of bigger battery because you didn't condition it yourself. I could be wrong so don't quote me.
Kinda defeats the purpose of a slim phone
I simply carry an extra battery which is so small, you don't notice where you put it.
In my case, it fits in my phone case (sunglasses soft pouch).
