Root Wrong Kernal for Wireless Tethering?
darkside
So I am rooted running BB0.4 1.1ghz kernal, and when I try to use the Wireless Tethering for Root users app, it gives me an error saying that the kernal I have doesn't work. Do i need to flash a different kernal to get it to work? Or should I just ignore it and continue. When I hit ignore and looked at my wireless networks I don't see my phone. Any ideas?
Im pretty sure the kernel that comes with BB is just a slightly modified stock kernel and that wont support wifi tether. Check out the Froyo Kernels sticky to find a kernel. All the kernels in that thread should support wifi tether.
question...when flashing to another kernal, do you have to remove a prior kernal to flash to another or can you just flash another kernal on top? I flashed a 1GHz kernal on my simplystunning froyo ROM and lost the battery percentage widget as well as the boot animation that I really liked. Not sure if that was actually an intentional kernal design or the kernal just not liking the ROM/ being fidgety with my phone....it seemed like it was booting/rebooting for quite a while after initially flashing the kernal. Any thoughts?
that should be supported Im not sure whats going on then
Ya i've tried everything I can think of. I flashed to chevy's ULV 7 slot 1.25ghz kernal as well to see if maybe that will work and still nothing, getting the same error. Tried to turn off access control and still can't find the phone from my laptop. Not sure what else to do. Going to try and reinstall and see if maybe that helps.
I just flashed from Chevy's LV 1.1ghz kernal to his ULV 1.25ghz kernal and everything is working like it should, I can overclock to 1.25ghz now and it shows it in my kernal version. I flashed right over the old kernal i was using so it should work to my knowledge.
So I found out that I was using one of the old versions of Wifi Tethering, went to the market and downloaded the current one, and everything is working now, Didn't know the app on my sd card was an old one so thus my problem. Thanks for the help.
nevermind....I have wifi tether...and Ia m currently overclocking at 1ghz....I think I can live without the battery % widget lol
