This phone is so cool but this dropping signal all the time is starting to annoy. When is Google gonna fix this
It's more than likely going to be a T-mobile problem more than anything.
I'm pretty sure Andrea is on AT&T.
You are correct and its not a signal as in the bars its the connectivity. No matter if I have full wifi and bars there will be times the whole thing goes white which means a connectivity problem. So what's the malfunction. I mean it already only has edge on att and now it has connection issues?
I'm assuming the problem shows up when switching between Wi-Fi/3G/EDGE? I know mine has a slight lull when I switch off of 3G and onto my Wifi, but that's not unusual. Maybe AT&T's EDGE towers near you are on different technologies and incapable of switching seamlessly between each other.
Mine does the same thing but it's not when I am switching from wifi to 3g. It will do it when I have been on wifi and randomly drops the signal and it takes a while to reconnect. Whenever it turns gray it means I'm not connected at all.
My fiancé has a nexus s as well and this only happens to her once in a while. But it happens to me several times daily.
