ColonelPanic
You can have your screen time out set to "never"? I never saw that, also wouldn't that kill battery life?
Once you change the setting. Just set it super high like 30 minutes. If that is your issue you should notice a difference. The prox sensor should disable it.
Have you tested the sensor to see if it is working ? I ask this because if it doesn't work to start with, the screen is definitely timing out. Just make a call and put your thumb across the top of your phone while in call and see if the screen turns off.
