I am using the Xoom to replace my MyFi on Verizon so hotspot is key.
Enjoy. Let me know how it's working? I wonder if my Xoom sleeps and I put it in my briefcase while the laptop is tethered does it still work? Have not had any real time to experiment.
I am using the Xoom to replace my MyFi on Verizon so hotspot is key...
How does that work? I've currently got a Mifi w/ Verizon, but when I checked on upgrading it to the Xoom (just online...not at a Verizon store), it said upgrading would require a plan change, which I don't want to do, since I've got unlimited data grandfathered in at a better price than what it's currently offered.
When I get my Xoom next month I am getting the wifi only version because I use wifi at my house most of the time and when I am on the go I can use my Samsung Vibrant as a mobile hotspot and get online on the Xoom that way.
Yea, I suppose the mobile hotspot takes up a lot of battery life in your phone.
Verizon doesn't charge any fee for using a Xoom hotspot since that is one of it's intended uses - they just deduct data used from your Xoom data plan. On the negative side an unlimited Xoom plan isn't offered.
Is that true? I was going to hotspot Saturday but realized I am on the cheapest plan and I figured that I needed a higher plan. Are you positive or should I contact Verizon?
