I am viewing this site from my new xoom and it is crystal clear. Not blurry not pixely, nothing. If you have not used one or don't have one, why not reserve passing judgement for those with Xoom experience.
there was a mention in an article about it i think. it has to do with the capacitive touch screen technology perhaps. Might be the same thing they describe and it might be different
I was alone in the Verizon store for about an hour, and went back and forth with the iPad screen and the Xoom. The Xoom screen is slightly less bright, and slightly less saturated then the iPad screen.
Were you using auto brightness or did you manually set the backlight to max?
I tried it with and without. The auto-brightness seemed too dark for my taste although this was under some pretty strong retail lighting.
Auto is definitely too dark, maybe thats where they get the 10 hour battery life!
its from the BGR reviewIf there is any chance you could point me in the direction of the article, that would be great!
Also, again if anyone could do some pressing on their screen and see if they get any weird artifacting and let me know, that would be great.
Thanks!
The Motorola XOOM
Thanks!
Let's get one thing straight, the Xoom's screen has a higher resolution than the iPad. Xoom is 1280x800.
Personally I love the screen but I'm biased.
I think the concern is the Ipad 2 will blow them both away, and at a cheaper price point.
Viewing angles appear to be 180 degrees.
Just like the G-Tablet!![]()
