Frisco
=Luceat Lux Vestra=
[ROM-beta][GPL][9/9/2010] xtrROM4.5 [cache2cache,apps2sd,jit,lwp,oc,flash10] - xda-developers
http://zach.xtr.i6ix.com/xtrROM4.5-beta.zip
From zach's notes:
Default ROM Configuration
You do not need to run any scripts unless you would like to change the following default configuration:
From zach's notes:
- Live Wallpapers: Not supported (you must run GSript to enable)
- dalvik.vm.heapsize: 24m
- min free memory values: "balanced" (1536,2048,4096,10240,12800,38400)
- CPU Settings: Overclocked (Min-245760 Max-710400)
- Just In Time Compiler (JIT): Off
- Cache Location: Cache2cache On
- Apps2sd: Off
).. I have found no reason to "upgrade" as yet, although I do flash and test them for zach, along with many Froyos.
