Peter123
I have just installed XtrSense4.06.0.1 - it is AWESOME.1. For starter, I made titanium backup fro all apps,
2. made nandroid backup
3. Copied everything to PC
4. Added the EXT3 partition
5. Copied back the SDcard content
6. Copied the ROM to the SD root
7. Wiped all and Flushed the ROM
8. Setup sync
9. Setup gscript; added app2sd and cache2sd, everything else left to default
9. Restored my apps using the Ti-backup
10. --- The ONLY thing that did not re store quite well
was swype beta. I re-downloaded swype beta. Now it works.
Summa summarum:
Everything works, (I have not checked Google voice though), fast, really fast.
With 10+ plus apps installed the phone's internal storage now has over 140 Mb free space.
The speed difference showed up remarkably the I ran Maps in Sat view. the loading/displaying new tiles of the map is much faster now.
Zach, congratulations, you have created a Masterpiece.
I also wantet to thank others (LED, Frisco, OTD, scary alien, KarateExplosions6) for help and encouragement.
Peter
