yakju steps simplified??
northernale1
Jul 24, 2010
328
27
does anyone have the steps to change to yakju in a real simple form or maybe even a vid?
never ever rooted before so would like to try this first step..
is there a way of doing it without going into dos prompts?
i have canadian GSM version on 4.0.1
and running win7 64 bit,,,
thanks for any help
Get the latest version of Wug's toolkit here: Wug's Galaxy Nexus Root Toolkit
Make sure you follow the driver setup instructions...they are step by step and take a little while, but they are crucial to success. Then, click the "Flash Stock + Unroot" button...it will prompt you for 4.0.2 and you click yes. Process takes like 5 mins. I was a ROM noob and I didn't have any issues at all.
Upvote 0
does the program supply the 4.0.2 rom.. or do i go and get it??
Upvote 0
BEST TECH IN 2023
Smartphones
