Yellow tint/yellowish whites
BWOMP
I have the AT&T version of the Note and I have noticed that the whites have somewhat of a yellowish tint. I compared the note to several other phones and it makes the yellowish even more noticeable. I have adjusted brightness, which helps a little, but it is still noticeably yellow. Do I have a bad set, or is this just the way the screen is? There is no way to adjust RGB that I have found. Please let me know if any of you notice a similar issue so I can confirm this is normal or if I have a bad display. Your help is greatly appreciated!
Ben
I've noticed the yellow tint as well especially next to the iPhone 4s, but i'm not sure if it's a bad screen or just a "feature" of the AMOLED display.
Supercurio from XDA is creating an app to adjust and calibrate the display. He is still working on it. The color issue is due to coding and not an inherent fault of the screen.
I have heard that. I donloaded his app that has the black overlay, but it does nothing more than my brightnness setting. I'm looking forward to his ap. Good to hear that its just the way the phne is and there is nothing wrong with my devie.
I know the SG S2 and Nexus have similar issues. I know on the int version of the Note there is a screen mode setting that can be changed to dynamic, but the ATT version does not. Any idea as to when his app might be ready?
