Root Yet another question.
Targaryen
Member
Ok during aroma installer on reloaded there were I believe about 5 options of different versions or something. one said deck something or other don't remember the rest. I chose the deck one. This was before you choose recommended setup or custom. Anyone know what these different things are? If not my other plan is to reflash and try them and while I have a lot of time on my hands I don't want to go thru it all
The first one is how you want the aroma installer themed. It wont affect the ROM no matter what one you choose
A class 6 or higher card is recommended. You can pick up a class 10 16GB card for around $15 online
Cool thanks, so may as well leave alone and just set this thing all the way up
yes just set it up but you need to hurry because soon you'll discover another ROM that is really *itching and you'll have to of course try it out I mean after you have a rooted phone and what good is a rooted phone if you just setup and leave it alone :boring: DONT BE ONE OF THEM :D
Shut up I've been on reloaded for like a week :p
I run a class 4 32 gb SanDisk and it doesn't give me any problems. In fact I was wondering if anything above that might be overkill? Just because I don't have any problems loading up apps or anything and I'm partitioned with dalvik, data and all apps 2 SD.
I don't think I'll be I've of THEM, but man they did a good job on this. I've still done a few different flashes since reloaded but within a day I'm back to reloaded. If miui.us can fix just a few more thing's( specifically the crappy internet) then I would like to use that more. I like that they come out once a week. I've probably flashed 50 roms that weren't for me in the last year and decks really seems to do it.
