Help YouTube Problem
When is Sprint going to come up with a fix for YouTube not working on 3G. It works fine on 4G and wifi. There are others with the Evo as well as the Shift who are having this problem.
it's not youtube, but an issue with your 3g tower.
in some cases you can do the 3g fix and get better connections ....others you would need to take more drastic measures (towers completely out with no fix..root, custom prl's forced data roaming etc etc etc )
I have tried YouTube in different locations in my area and I'm sure I have used at least 5 - 10 different towers with the same result. It works on 4G and wifi and doesn't work on 3G. What do you mean by the 3G fix?
