Zerolemon Extended Battery
Thanks for the reply. I haven't charged the battery since i posted that and the phone seems to be adjusting to the new battery. It's weird, when it was at 100% charge the system said I only had 7 minutes of battery life, and proceeded to drain as if I had the old battery. Now, I have a 67% charge and the system is showing 1 day and 8+ hours of battery life. So I can only assume the phone is adjusting. Yes I have juice defender, I'll take your advice and disable it to see if that changes anything.
I definitely recommend disabling Juice Defender. You can always enable it again, but I think that the power saving apps are not as good as the normal system. I don't think that Samsung or any other phone maker tests those types of apps. I could be wrong, but you have nothing to lose and everything to gain if I'm right:-)
One other thing is that you need to make sure that you followed the instructions that came with the battery (5 or 6 charges to complete discharges, followed by a complete recharge). Also, are you using an OEM charger? I found out when I was looking for an extra charger that they had an issue with them and they are very hard to find. I ended up finding one online and it is 2.3 vs the 2.0 that is sold. There is (at least to me) a noticeable difference in charging speed.
Good luck
Yes, I am using the original charger that came with the phone. I have disabled, and am now considering uninstalling, Juice Defender. I'm also doing as the battery's manual says by not charging it until it has been discharged.
So far, lol, I've got to say discharging this battery is more difficult than keeping the charge. It seems you'vesolved my issue, thanks a bunch.
I wonder if you have a defective phone. There is no way that you can be at over ninety percent yet have only seven minutes left-- not even with the original battery.
Actually, my stupid self read it wrong. It's telling me how long I've been using the battery, not how long i have left on it.
Hey folks, got my zerolemon 9000 milliamp for a note 2 this morning. It's currently on the charger. My phone does this weird thing where when you plug it in to power, it auto reboots. Even if it is plugged in to the charger and I power it off, it automatically reboots. Do you think this will be an issue regarding the initial 12hr charge?
Hmmm...that should NOT be happening. You should take it back to the store and have them put it on the tester. There could be a lot of reasons as to why it is rebooting when on a charger, but that should NOT be happening.
It doesn't endlessly reboot. But if I turn it off and plug it in to the charger, it turns back on. And if it's plugged in and I turn it off, it will power on again immediately.
It was doing this on the original battery as well.
I shopped Amazon for extended batteries and cases before I got the Note 3. Once I had the phone I got the Zerolemon (10000mAh) two days later and really love this combo. I do have big hands so the larger case/battery combination doesn't cause me any issues there. I am currently getting 40+/- hours per charge with the majority being talk time and screen time. Best accesories I've ever purchased for a cell phone and any future phone will be powered ad protected by ZeroLemon.
I have the Zerolemon and the Anker 6400 extended battery. I do prefer the Anker. Allows my phone to last all day with moderate to heavy use and is not as heavy or bulky as the zerolemon.
Plus I don't really like the feel of the zerolemon case. I was able to modify a otterbox defender case and put my Anker extended battery in and works great and the feel of the otterbox, in my opinion, feels better in the hands than the Zerolemon
I'm interested in what you had to do to get it to fit with the Defender. could you give some details on that and maybe some pics? Pretty please? :)
I'll try to explain here and if needed I'll take some pics.
So the defender is basically comes in 3 pieces.
1. The front plastic piece with the screen protector
2. The back plastic piece that goes around back of your phone
3. The TPU rubber outer case.
Well I used the Anker extended battery with the battery cover that came with the Anker. I did NOT use #2 above, the back plastic piece from defender, instead used the back piece that came with the Anker battery.
So I slide the front piece (#1 above) over the phone, and carefully placed the entire phone into the TPU outer case. It is a very tight fit, due to the small bulge of the back of phone from the extended battery, so you may need to stretch the TPU case a little but don't worry, it will not rip or break. Make sure everything snaps into place, around the corner of the phone with TPU case
It will be very sturdy with a tiny, barely noticeable bulge in back due to the battery. Only issue I found is the power rubber button on the right of the case and volume buttons (especially the lower volume) does not sit exactly where it should over the actual phone. Visually you cannot tell but when you go to press, like the volume down button, you'll have to push it in a slight angle. Not a big deal for me, and I think a very small tradeoff for such a comfortable case and battery life.
Case feels a million times better in my hands than the Zerolemon case, which I also have, or any of the crappy cases for the Anker battery.
Now you have the protection of the otterbox defender case, and double the stock battery life in your phone. This, for me is a keeper, . I was changing cases like crazy before, but I think I finally found the perfect setup for my Note 3 😊
Sorry for the bump, but I was just wondering how you Zerolemon owners fare in regards to fitting the thing in your pocket? Is it too bulky? Do you end up using the holster instead?
I'm going to Disneyland in a few weeks, was wondering if I should either splurge on the ZeroLemon, or just buy this two-pack of Anker batteries to make my phone last the whole day. I already have one spare Anker, so with these I'd have three spare batteries to carry around (which could just go in the gf's purse). Or I could go ZL and carry it around, but I just wanna get your guys input on how difficult it is to fit in standard jeans pockets, which could get challenging with walking around Disneyland the whole day, and repeatedly taking it in and out to use the camera and stuff.
I carry mine in my shirt pocket fairly easily but it is a little heavy. I guess it would come down to how tight your jeans pockets are, I've read about a few people carrying on their jeans pockets. The holster is a good option too in my opinion, it has fast access for what it is.
Fits in my jeans pockets no problem. Just a small bulge. Just don't leave it in your pockets and drive!
I guess you can use a holster, but I never do. .
You do get used to the size so it's not a huge deal. Only issue is with gym shorts. Be careful because it can pull your shorts down! :)
I have had the Zerolemon case and battery since the early part of the year at least 6 or 7 or more months now.
The bulk of the battery and case are not, to me, a disadvantage. Rather, I am glad for the case. Although I try to be very careful, I have dropped the phone two or three times from at least four feet without any damage whatsoever. It is true that the case makes the whole thing about three times as thick, but I felt that the phone in its original configuration was too thIn: it felt fragile to me although it probably wasn't. The increase in size makes the unit feel both solid and more comfortable.
With the Zerolemon case, it will just barely fit into a dress shirt pocket. Because it is a snug fit, I do not worry about it accidentally falling out. It will also fit easily into the front pockets of most trousers and shorts. (I would NEVER put any cell phone into a back pants pocket; in my opinion that would be just asking for trouble.)
The holster works well, except the belt clip sometimes tends to dig into me. The phone has never fallen out of the holster if the phone has been fully placed into it. (I had a somewhat similar holster from Otter Box for my previous phone, a Blackberry, and, while the phone case was excellent, the holster's phone retention clips broke off with only a few day's use-- twice!) I find myself using tis holster only about thirty five percent of the time. Most times I just pocket the phone.
Battery life: the Zerolemon battery usually gives me 12 to 14 hours compared to about 5 for the original battery. Most users will likely get longer times than these, but I access the Internet a lot and I do a lot of writing with Google docs, which instantly synchronizes and saves to the Google cloud, and therfore does more Internet accessing.
I also use the devise as my primary GPS unit. I say primary because in some critical situations, I will also run a second, GPS only unit, a Garmin. One lesson I have learned with this Note 3 is that starting a GPS program can some times be SLOW. A couple times I thought the GPS was broken, but it only needed more time. Once underway, it worked.
GPS uses a lot of battery, more than any other operation, so I always connect to the car's power outlet when GPSing (is there such a word? If not, the should be!) .
Are you talking about 12-14 hours of onscreen time? . Because the other day I averaged only about 9 hours of onscreen time with about 30% battery left, which is OK but I expected better, since that's what I normally get with my Anker 6400 mah extended battery
I think it also depends on what you have running in the background; my phone very often runs hot because there are apps running in the background. My very strong impression is that there are a number of apps that will run even though you have not use them recently. Because my phone sometimes gets quite warm, I am concerned about this, and I am slowly going through my apps and removing every one that is either not well written or not that useful to me. I started out with this phone by installing a very large number of apps that I thought might be of interest and/or usefulness. Now I am getting rid of many of them, and one of my criteria is if it seems to start up and run in the background even though I have not used it since the last time I turned the phone on.
I suspect that the authors of those programs design them to start up when the phone is turned on so that when I go to use them I will not have to wait for them. But when you have a bunch of programs running in the background, it seems to me to make the device run hot and shorten battery life.
Perhaps someone on this forum that knows more about the Android system can tell us for sure whether a significant number of programs will, in fact, run in the background even though they have not been used since the phone was last turned on. I don't know that for sure but the programs that claim to free up system memory make me think that this is the case.
I recently.2weeks ago got my Zerolemon for my Note3. After my initial 12h charge my phone died around the 5-6th day with light use, I mean mobile date/wifi/sync all the time with 1-2hour of music while working out and surfing. Not that heavy really, I put on the stuff I need at all times like emails closing and ot closing the apps in task manager.
Im now on my second charge now and im waiting on it to die so I can recharge it,but I gotta say the zerolemon is well worth. With my use I only prolly gonna have charge my phone only 1 time a week around 6-8days which is really impressive.
So I ended up getting the ZeroLemon. I spent yesterday at Disneyland, took it off the charger at around 9:00am. Mainly was using it to record video and take photos, by the end of the day I had shot around 120 videos (clips ranging from a few seconds to a few minutes). Also used it while we were in line for web browsing while waiting in line. Had it connected via Bluetooth to my Moto 360 as well.
This thing is still going, it has 26 percent left after almost 25 hours after taking it off the charger. Screen on time is currently at 7h 18m.
Size didn't bother me too much, only qualm I have about it is the S Pen is relatively difficult to take out, compared to when I have my Otterbox Commuter on. Overall, well worth the purchase, this thing is definitely handy when you're gonna be away from a charger for a while.
As a real heavy user of LTE, a removable battery gives 100% of the stored charge. I love extended battery, especially if it's 10000mAh, giving me more than a day's worth, with at least 10 hours of SOT.
I just don't see how these sealed limited batteries being a step forward. Fast charging /fast wireless charging will even shorten the power holds on these things. I'd like to share my first 20 cycles of charging.
EHUHex
So I'm getting 37 hours best projected time with the way I PERSONALLY USE my Note 3. I am usually on LTE, and yours may differ. I provided actual, and projected usage (proportioned based on percentage used, and percentage left). The longest I've used for one charge was 33+ hours consuming 92% of the battery on the 4th discharge. However, by also consuming 92% on the 7th discharge, I only got to use it some 15 hours, all because I had 2 more hours SOT, and 4GB more LTE data. The higher the LTE data consumed, the faster the battery will be drained. The lowest projected performance of the battery is just below 17 hours, if I consumed 7GB of LTE plus the fact I had more than 10 hours of SOT (again, 7th cycle).
The average of my real usage is 18 hours, 7.5 hours of SOT, almost 3 GB of LTE, and average 66% of the battery before I charge it for the day. I'm basically charging nightly. It can go on for another 15 hours, but I'm using this as my daily driver, NEVER worrying or having to change battery.
I'm now thinking of getting another one just so I can just switch when I need to, and leave the spent battery on a timer charge at home.
Just chiming in, now that I saw this thread.
Have a ZL battery on my SM-N900 Note 3. For those in the know, it is no secret that this is the most power hungry version of this phone, and not even 4G LTE with anyone. That said, as my daily driver, it was getting me an average of two full days per charge cycle consistently. The only time it would get less, was on those times of the year when Games Done Quick was broadcasting its charity marathons on Twitch. A full charge and loading up Twitch app to stream the broadcast even over HSPA+ got me about 16-20 hours of video.
I've since changed phones. But hung on to this, as for the longest time, it was the only anything I had that could connect to 5ghz wifi. And now that we have such a router at home to feed it a signal, it'll get to be on airplane mode plus wifi access and enjoying several days at a time per charge cycle. At least until I need it as a phone again.
I got my first ZeroLemon batter (10000mAh) for my Note 3 around April, 2014. Still going strong, after more than two years. I can still get 2-3 days use with my Note 3.
I got a new Note 4 (2nd generation) November, 2015. The stock battery will only last around 5-7 hours. Just got the 10000mAh ZeroLemon battery for my Note 4 today .... Still on the first charge until 9:00 tomorrow. Expecting the same quality with the Note 4 .... Will report back with an update .....
I just got my Zerolemon extended battery in today's mail. I'm charging it now for the twelve hours it suggests for the initial charge. Actually, I had to start the process over after the charger plug got accidentally yanked out of the phone. Hope that doesn't hinder the process any.
The battery comes with a rather bulky but rugged case. The case and battery add some weight to the phone, which I need to get used to.
Anyway, I wanted to start a thread to discuss the Zerolemon and extended batteries in general. What are your experiences with the Zerolemon? Do you use a different brand of extended battery? What kind? Does it come with a case? Does it fit a case you have currently? What else can you tell us about your experiences?
I just purchased my second ZeroLemon battery and clip. The first battery still works, but I found myself charging it almost daily, so I felt that it was time. The belt clip seems to have been replaced, but it is still flimsy and breaks easily (in shipping). I still think this is a great deal overall.
