Will this work on AOKP!! Oh and thanks for everyone's hard work...
Nevermind already answered.. Thank all of you for getting this to work...
Ok so I just had a big breakthrough. I have MMS sending and receiving using the latest CM10 MMS.apk from Dastins ROM. This is JB MMS with all the features and should have sms split and quick reply with popup! This is what we all wanted.
Download and Flash this file. Make sure you remove the previous versions you may have installed.
PS. This is pure WIN!
Just tested this and it works. Well I didn't flash the zip. Just moved the app to the system/app folder and changed the MMSC in the apn-config.XML file. :3
That is what the flash does too! Thank you for confirming it works.
Success with AOKP for me.
That might have been due to the updater-script resetting permissions on the files in the /system/app directory. I don't think the files it is installing or deleting would have anything to do with Swype. It could be changed to only reset permissions on the MMS apk.It did for me too noticed that it also switched the keyboard to swipe word (pop up) which is nice... had that on mobsters V3 and really liked it. probably been there the whole time just didn't notice lol.
any1 want me to retheme the full mms apk to lenses dark theme and my theme... or are you guyz satisfied with the clean stock look???
I like the dark theme as well.
If it's not too much work I like the dark theme, but if I'm the only one don't go through the trouble
Attached is an updated version of the installation zip for the Mms.apk from GANGNAM that now sets permissions only on that app, deletes dalvik and formats the cache partition. Hopefully that will resolve any remaining quirks.That might have been due to the updater-script resetting permissions on the files in the /system/app directory. I don't think the files it is installing or deleting would have anything to do with Swype. It could be changed to only reset permissions on the MMS apk.
The boot loop David had might also be related to some new app running that had it's permissions reset, although I've had problems in the past with the ROM's based on agrabren's CM10 not booting after installing mods or even changing parameters.
It would be a good idea to format cache+dalvik after flashing the zip file, or that could be added to the updater-script.
Note to krowley3: I had to change the update-binary because the original version didn't support formatting cache as ext4.
ramjet73
No need to credit me. All I did was help with the packaging.Again, thank you for all the help. I have uploaded this file to my dev-host account and am linking to it in the AOKP thread with credit to you. I will do the same in Dastins thread. If you have a problem with this, please let me know. I really appreciate you help with all the scripting as that is not my strong suit.
Ok, I have posted this in AOKP as well as Dastins CM10 thread on XDA. I will do the same on the PACMAN thread if I hear that it is confirmed working. This is the same file that Ramjet posted a few minutes ago, I just uploaded it to my Dev-host account.
Here is a flashable fix for Virgin Mobile users like myself. This has been verified working over at Android Forums. This will simply replace the apns-config.xml and the Mms.apk. A big thanks/credit goes out to Ramjet for helping out with the updater-script and binary. Please let me know if you have any questions about this.
CM10/AOKP Virgin Mobile MMS Fix
Credits:
Myself and Ramjet for the flashable zip
Myself for the Mms.apk
wolfu for the apns-config.xml
davidmargolin for bringing us all together with a partial fix
Updated download in thread or OP
