fullbloodedmut
alright guys,quick question for you guys.if im using my backup root,or any other app like,and i make a bkup of my apps+data,now when i zip them up,how do i make sure that in that zip i created,everything is in it?my prob is im running out of storage,so i figured that if i zip my bkups,i can delete the bkups and keep the zips since it changes the size and gives me more space,now if im doing it wrong and there is a diff and safer way,please point me in the right direction!! and the whole bkup thing,should i just store them(apps+data) on my external harddrive and not on the device?i prob should just keep the recovery bkups on the device at all times,so if i have a prob,then i could go to them,and then just get the apps bkup from comp?is this correct,or am i wrong? THANK YOU ALL for any input!!!!
