Should I do nothing and do a factory reset? Please help I feel like I might have ruined a brand new phone
And yes my phones working can I delete the backup and unroot it start over?
well the USB 8gb flash drive I borrowed will not format so I just tried to boot from the Iso in my friends older Pentium D dual core Dell GX620.
I am getting an error that the "Your device was not detected. Press ENTER to Exit"
I tried the phone in "DFU mode by holding both vol up and vol down along with power" and recovery mode, restarting the iso with the phone already in download mode and plugged into the usb.
my friend was thinking maybe I need to "click" somewhere in linux and mount or ??? to get it to detect the phone???
Talked to junkie2100 earlier. We have been working on a ZTE Unbrick Tool. It should get CWM installed so you can flash roms. This is a very early release and is by no means finished. In fact I put it together for you and your current situation. It is an iso image that you need to burn to a cd or use to make a bootable usb drive. Once you have the bootable media created, boot your pc to it. You may need to adjust your pc boot order in the bios to get it to boot.
Once you get it booted on your pc, put your device in DFU mode by holding both vol up and vol down along with power. Plug in your device, click the green android icon on the desktop, press ok or enter on the password prompt, type "gordon" which is the codename for your device (you will see a chart) and press enter. Confirm with "y" then press enter, and wait. Let us know how it goes.
Download:
gordon_test_unbrick.iso
I'm trying to unbrick my ZTE Flash N9500 with this tool, but password is wrong, please help me !!
After I read this post Felix the cat and you posted was I supposed to type gordan in as the password or root like you said in this post? Please get back at me thank you.
Yes, I opened tool with 'root' passwd, then I put my ZTE Flash in DFU mode (vol down+vol up+pwr). I used 'gordon' for codename but my device was not detected...
damn I'm gonna have to try it again I'll let you know
it is unlikely the tool will work for you. It was originally designed for msm8930 devices, and the flash is an msm8960. Apparently msm8960 zte devices do not mount as block devices the way msm8930's do. When you run the tool it will probably tell you your device was not detected...same as RCAIN1 above. If we find another way i will post back.
why are you posting here then lolI know im not in the right thread but.....
You will need to setup the windows drivers for your device and your device needs to be rooted to install cwm.I was wondering supers how or what do I do to go about flashing CWM when I try it says that my device is not listed is there anyother way to do it?
CWM works on the flash and all other zte's i have encountered so far. You just need a version made for your device...which you have available.Is CWM worthless to ZTE?
Lol I have CWM pro I and all my drivers are good I just cant get it to recovery from the CWM app on my phone having troubles
.can I use fastboot to flash cwm to my zte flash ? And if so how? (I saw ur post about using cmd prompt but I'm still a novice and fastboot seems easier...)
