This may be a run on paragraph so I apologize ahead of time.
I have an issue I am trying to track down.
Phone: zte warp
2 batteries: factory 1600mah that came with the phone and a new 3800mah.
issue: new battery charged thru the phone drains just as fast as the stock battery. Nearly identical drain. Unplug at 7am and down to 75% 3-4 hrs later.
charge setup: dual usb slot wall charger plugged into a power strip.
charge: 5-9 hrs
When it charges it says its 100% and no charge is showing so its as if its fully charged.
Here is the scenereo I have.
I bought the new 3800mah on my brothers card (since i have no cred card)
After about 3 weeks the battery came in, so I went to pick it up. When I got there he said he had it on the provided wall charger that came with the battery.
I decided to test the new battery out for a bit and ran it down to 80%.
After that at 9pm decided to charge it to 100% again. At 12mid i decided to give the battery a vigorous test and unplugged it and see how long it would last. I ran multiple videos (3-5), surfed about 3-5 hrs on multiple web sites, played a few games, made some phone calls.....all in all I'de say avg to moderately heavy use, and after 22hrs I still had 32% left. I was rather surprised and well pleased. That was day one.
This was on the provided wall charger out of the phone ie: the battery wasn't charged useing the phone.
I then charge it overnight in the phone about 6 hrs. I wake up check the phone and it says 100% and no charge symbol (full charge). Took it off the charger at 7am and at 10:30am I am at 80%, this is with 1 youyube video about 5 mins long, and nothing else.
Now it seems somthing somewhere is messed up because with almost 3x more usage the day before I got way better battery usage, now it's no better than my stock 1600mah is.
Things that changed are: usb wall charger and charging thru the phone.
After all this speel, my question is what went wrong or what am I doing wrong, if anything??
I am going to take the battery out of the phone tonight and charge it with the wall charger like the.first time to rule out the battery, but am at a loss as to what the issue is.
Is it possible that the phone could have a charging issue, and charging thru the phone doesn't get a true full charge? if so I may have to contact zte.
Phone: zte warp
charge: 5-9 hrs
. I was SO looking forward to having the extra battery life. Oh I could use the battery and wall charger, that's true, but can you imagine the abuse the back phone cover would take, taking it off and on, even at every 2 days charge, over a extended period of time the back would be wasted and of no use, and then I'de really be in a bind, because the backs aren't exactly plentiful.
