Help zte warp lcd replacement problems help!!!
So I replaced the lcd screen to a ZTE warp and the screen is discolored does that mean I have a faulty lcd or is their a way to fix that here is a pic.
Check the ribbon cable to make sure it isn't cracked and that it is fully seated in the connector. If all that checks out then it may be a faulty screen.
