Root ZTE ZMAX Pro (Z981) "device donation" root discussion
ASAP How did you get Temp ROOT. I need it to boot su
Check to see if you are affected by the two quad rooter exploits and if so both codes are available on meta sploit.
Just run each one in script form so you can run both at the same time, just dont forget to add a copy of su from either supersu or superuser. Quad rooter only weakens the system and gives you enough time to copy the file over.
Thanks. Any links, info. or anything that you may think can help please message or post. I'll post my progress of course.
-TheHalfrican
ZTE:
Zeus The Evil
Checklist:
Unlock your phone. Go to “ developer option” and “ unlock OEM”.
Download TWRP and ADB Tool
Install ZTE driver on computer.
TECHNIQUE SQUIDWARD, DONT FORGET THE TECHNIQUE!!
Let's get Rooted!
Restart your phone to bootloader (“ volume down” + “ battery'
Open up your adb tool and rename TWRP as “recovery”.
Drag it into the ADB toolkit and input the command: “fastboot flash recovery recovery.img”.
When finished, type “ fastboot reboot” then reboot into system.
Transfer SuperSU into phone’s internal memory.
Find the suitable SuperSU versions ( SuperSU V2.64 and SuperSU V2.79)
Turn off your phone.
Then press “ volume up + start” to enter recovery mode
Install SuperSU by sliding it right in Reboot.
RESULTS?
Sorry buddy but we don't have fastboot
ZTE:
Zeus The Evil
Checklist:
Let's get Rooted!
RESULTS?
Acknowledged​ & Disregarded: We also don't have 'root access'... Statements of this caliber are for lack of words pointless.  Now I'm going to 'flash fastboot' onto a Z981. First attempt was interrupted but I have some extras to toy with.
You cant flash fastboot nor can it be accessed as it is locked out.
I'll send you think thread link when I find it. I'm not trying to be that "Nuh Uh You're Wrong" guy, so once again excuse me if I come off rude but I saw and understood the video.I didtnt know how to save a threadand lost track of it creating a profile, so Im looking, But heck it couldve been running kitkat not mellow.
*SAVING POST SPACE*
Is there a search for member option lol i that might make it easier.
