Sands207
Did you trying putting ##72786# in the dialer?I swear I thought I read there was a complicated key combo that worked. I may have imagined it though!
Did you reboot after using the dialer code and then try to update your profile & prl?Yes, it didn't say authentication error, but some kind of error popped up.
I maybe its just because i just woke up and I'm working on my first cup of coffee but I planned to install this today but im running the no carrier specific ROM now, how should i flash this is cwm? Should i do the factory reset, normal wipes, flash this and super su, and then wipe cache and dalvik? I really don't want to go without service, the voicemail doesn't matter to me because i rarely take or make phone callsThat's it! I did do all the usual wipes. Good job, I was stumped on that one.
Cool, I'm going to check it out. Everything works okay now?Ready for action!!
Removed AOSP apps...it's no use trying to use 'em.
Oops I forgot the link: https://www.androidfilehost.com/?fid=95784891001611130
The new build or ...?Anyone running it?
Only me. I still have a few bugs existent.
I'm going. But...a general warning inside the ROM. NEVER, EVER, UNDER ANY CIRCUMSTANCE SET THE LOCK EFFECT TO SPREADING INK. YOU WLL HAVE TO FACTORY RESET BECAUSE SYSTEMUI WILL CRASH.If you need any testers I'm down. I'm on VM.
Oh yeah, I did run that one. It ran fine. Just a bug (might have been VM) where activation didn't work. (Running ##UPDATE# did run HFA [Hands Free Activation] just fine though...)Sorry, I meant the one you posted last night. I thought Sands was gonna try it.
Yeah, I flashed it this morning and everything seems to be going fine so far! Are you using Linux or Windows to bake your ROMs? I tried to make one from the original one donjuro posted but I had to test it myself first and I got status 6 over and over again no matter what I tried so I took a break to learn more. my guess is that the updater-script didn't compile right. I deodexed my favorite apps and made ViperFX and Greenify &WiFi tether system apps with yours, and flashed that deodex zip and then the latest gapps and SuperSU and everything seems smooth so far. I had to do the HFA but I'm use to that with the volt now. I'm just theming now, great work manOh yeah, I did run that one. It ran fine. Just a bug (might have been VM) where activation didn't work. (Running ##UPDATE# did run HFA [Hands Free Activation] just fine though...)
I use Windows, Notepad++, and WinRAR. I make sure that the updaterscript has no lines that point to a nonexistent file. Check the script and make sure that faulty lines are taken out..☺Yeah, I flashed it this morning and everything seems to be going fine so far! Are you using Linux or Windows to bake your ROMs? I tried to make one from the original one donjuro posted but I had to test it myself first and I got status 6 over and over again no matter what I tried so I took a break to learn more. my guess is that the updater-script didn't compile right. I deodexed my favorite apps and made ViperFX and Greenify &WiFi tether system apps with yours, and flashed that deodex zip and then the latest gapps and SuperSU and everything seems smooth so far. I had to do the HFA but I'm use to that with the volt now. I'm just theming now, great work man![]()
