Root ZV4 Sprint rom needed to force roaming
I am looking for a ZV4 based Sprint rom so that I can access the LG hidden menu and enable forced roaming. The only ZV4 rom I've found that's still on the forums is the boost version of Marquee Beats. I tried searching the forum but didn't find anything in the popular rom threads so if anyone can point me in the proper direction I'd be extremely grateful. Also for those that don't know they removed the option from the lg hidden menu in all ZVC roms.
I would try the stock sprint zvc rom. Change out the build prop mms.config (maybe even apn-config) and eri.xml and you should be good.
the rom would be "undeniable marquee," swap what asadullah said, plus the mms.apk and settings.apk.
I don't know if you got this yet or not but I have a marquee and I downgraded it to ZV9 and the network select works again.
