galaxy s4 I9505 soft bricked odin fail
Hello.
Today i tried to flash the stock firmware I9505XXUHPK2 BTU
After wiping my current os i went to download mode and flash the firmware but failed.It says
<ID:0/008> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/008> Odin engine v(ID:3.1301)..
<ID:0/008> File analysis..
<ID:0/008> Total Binary size: 2518 M
<ID:0/008> SetupConnection..
<ID:0/008> Initialzation..
<ID:0/008> FAIL! (DeviceInfo)
<OSM> All threads completed. (succeed 0 / failed 1)
Now my custom recovery TWRP is gone and it says
odin mode
product name: gt-i9505
current binary: Custom
system status: Custom
knox kernel lock: 0x0
knox warranty void: 0x1
csb-config-lsb: 0x30
write protection: enable
eMMC burst mode: enabled
please help.TIA
Just download the appropriate ver. of odin then find again the appropriate ver of trwp recovery and follow these steps
This step is just usable if the download fails
Go run the trwp recovery via odin "if it works then goto download mode again"
Go re-run the odin as administrator then flash your stock firmware
I really try this when i wanna flash my gt-i9505 using cf-auto-root
If this still doesn't work just ask to the other professionals cus im not that smart :)
No "Magic Eraser"
Often times on Pixels they introduce new stuff on the newest phones and push the features out to older Pixels that are still within the update timeline so long as the hardware supports it. You said you have recieved updates and that the error is a newer version is already installed. Can you check that you may not already have it?
OK, I did a little googling. It seems the issue you have is that Google coded newer versions of Google Photos to not allow Magic Eraser to run on older pixels. You need to first uninstall the version of Google Photos you currently have installed (hence the newer version installed error) and install the one from the link, and turn of updates from play.
This article kind of explains it.
https://www.reddit.com/r/GooglePixel/comments/qv4ttl/how_to_enable_magic_eraser_on_old_pixels_after/
Help bootloop!! Blackview a7 Pro
It says "orange state, etc"..... Not familiar with this. what comes after orange state? what does it say exactly? how did you unlock the phone? are we talking about unlocking the bootloader? or carrier unlocking the device?
give us in as much detail about what happened? what were you doing before it happened? just remember the more details you give us, the better we can help.
Help ANS UL40 Root
xda is always the place to go for root. if there is no forum for your device than that means that there is no dev community. just remember that no devs=no fun. so there is no custom rom. there is no custom recovery which is aa very important tool for rooted devices. there are no custom roms as well.....so why do you want to root the device?
Help Cyanogenmod Custom rom request and guide
omg you save my life i will try and i check it is work thanks so much
I Have another issues after try to install different roms my phone firmware it is broken the phone works but don't let me connect to my computer and don't let me connect to internet so i need to reinstall the firmware now
I fix the problem too I reinstall the firmware again I will publish in the new post too
App not "installed" but will run, keeps disappearing.
"Enable" implies that it is disabled. That will stop it appearing in the app drawer, though it is still installed. However it should not run when disabled. So what you describe would make sense if something was enabling and disabling it, but what that would be isn't obvious. Some phones have a setting to automatically disable apps that aren't used, but that should only happen if it's unused for months. If your phone has such a setting though you can probably exclude it from such disabling, or turn the feature off completely.
Unless you are rooted file managers are not a reliable way of looking at installed apps.
I have no idea what could be removing it. I used it almost daily.
Can't send text to one contact
I have a new to me Samsung A10e and signed up on Mint Mobile. My last phone was a Samsung J3 on Tracfone. There is one contact that I can't send texts to but can receive texts from her and I can call her. The icon by her name has a blue dot on the lower right, and when I switched to this phone and carrier, her icon by my name also developed the blue dot. How can I fix the problem of my not being able to text her? I transferred my phone number from my old J3.
So far I've restarted my phone, deleted and re-input her contact, and cleared the text message cache. I really need to be able to text this person. Thanks for any suggestions. Brigit-Carol
Problems with "Adopt good coding practices" step
I'm just starting to learn Android app development and kotlin and I'm working with the resources on developer.android.com. Currently I'm working on Build a basic layout > 3. Add images to your android app > 4. Adopt good coding practices.
In the instructions it talks about a warning next to the textView that I made in an earlier step and goes on to tell you how to extract the resources to your XML file so that the text is no longer hardcoded into your app and can be changed. The problem that I am having is that in my android studio there is no warning next to my textViews. I still want to make sure that the text is extracted to the XML file so I've been searching through help for that dialogue box but nothing has been coming up.
Here is the image from the tutorial that shows what I should be seeing:
here is what I am actually seeing:
Please help me figure out #1, why are there no warnings on my textviews, #2, how to extract the resources to the XML file.
[ROM] GamerROM 1 Home v1.0 For the LG Motion MS770 Updated: 2/5/2017
Welcome this is our newest OS to come to the device, however we built this blindly and hopefully yall give feedback to improve your gaming experience!
This New release isn't lollipop its Android v4.1.2 and it was rebuilt from scratch
Features:
* most apps updated and includes gapps
* Fast blazing Online gaming via GamerROM Online
* Unique UI and much more
Download: https://play.google.com/store/apps/details?id=com.gamerrom.downloader
Last Updated: 2/5/2017
Version: v1.0
Android Version: v4.1.2
Download: https://play.google.com/store/apps/details?id=com.gamerrom.downloader LINK IT IS BROKEN
Filter
