Help I Lost the Ability to Place and Receive Callss
[snip]
I'd suggest the simplest solution is probably to just type "<model name> volte" into your favourite search engine.
[snip
I did that and got a lot of links. Some don't list my model, others seem to imply that it depends on the SIM card.
I can't get through to H2O via calls email or chat to see if this is true.
Holy crap, as I was typing this I remembered I had an old T-mobile SIM card.
(I live near Nashville and Xmas morning 2020 an idiot blew himself up along with half of second ave in Nashville. That knocked out my ATT service so I went to T-moble and signed up for a month of service. Att came back in a week or so and I went back to H2O).
So I just put that old SIM in my phone and low and behold, under T-Mobile network I now have a new setting. "Enable VoLTE". And it is enabled.
So VoLTE is dependent on the SIM (service provider).
So maybe I wait for H2O to fix their problem (like they thought they did a month ago). Just use my google number for now.
Or go to T-mobile tomorrow and see what they have for plans.
Are There Non-apparent Advantges To Newer Technology?
My current phone (Sony Xperia XZ1 Compact) has a Micro SD card. I get a report:
Internal shared storage...Used space 17.6 GB
Free space 4.04 GB
SD card Used space 36.5GB (mostly pics. of my grand daughter)
Free space 82.5 GB
So I guess I am good with 128 GB
As Hadron suggested I started checking tests of batteries and the S22 doesn't look that good. I need to look some more.
But I really wish I could find a smaller phone then even the S22.
Help Moto G keeps resetting.
I also hate auto updates, have a Motorola, and the same issue.
After much grief and aggrevation, I stumbled quite blindly onto a sort of solution.
I have a certain cleaning app, quite possibly the only trustworthy one, that can be set to automatically clean the device once a day.
After I allowed the auto cleaning to occur, the automatic restarts stopped!
My guess is that although the auto update is turned off, the junk still gets downloaded and will pester either you or the system itself until it gets installed.
These things are installed automatically during restarts, so there it is.
So what I figure is happening now is that the cleaner is deleting the update data soon enough after it comes in that my device has suffered only one or two restarts in the last few weeks- whereas it was happening multiple times a day before.
Try it and see if it helps you as well as it did me.
https://f-droid.org/en/packages/theredspy15.ltecleanerfoss/
Now, @ocnbrze has a valid point about the age of the device.
This app may help, but the fact remains that you will need a newer device shortly.
You very well may have the same issue when the updates come through on a new device, especially if you turn off the auto-updates like I do.
So, even if you replace the device, I would still put this app on the new one and let it do its thing.
When you read the description, you will see why I say that it may be the only trustworthy cleaner around.
Also, if you don't know, F-Droid is the most secure appstore around- so don't be put off that the link is from a third party appstore.
Attached mouse won't power up
I tried this setup on another working Pixel 2 and it didn't power up either. I'm assuming something needs to be assigned in which case i'm out of luck. Can anyone confirm what needs to be turned on?
Yeah, I don't think it's an option you 'turn on' but rather the need to have some kind of driver/firmware installed in order for some external devices to work. In this instance it could be a driver could be required for the mouse or the OTG adapter/cable, or both. And it's matter where with Android something like a device driver is added via an app. So unless this is done back when the screen was working, that 'might' be part of the problem since testing this requires a Pixel 2 XL, and that specific brand of mouse and that specific brand of an OTG adapter/cable.
need to cast Android to pc through wifi, without lag
Please provide more details as your basic setup.
-- Are you trying to connect your phone to your TV using a WiFi signal from a router or from a phone hotspot?
If the former that will make interactions between devices more seamless than the latter.
-- What phone model do you have and which version of Android is it running?
Depending the phone, it may already include the sharing/casting features you need, without having to install third-party apps/services.
-- What is the make and model of your TV? Is it a smart TV (already includes its own existing, integral networking); or is it an older TV where you need to use an added, external dongle-type device (i.e. a Chromecast or a Roku) to add WiFi capability.
How can I make apps close when I back out of them?
I wouldn't bother with trying to constantly close apps, that's just micromanaging Android's memory management in a counter-productive way. You're not regaining usable RAM by doing this, it's just making your phone work that much more in the background to compensate for your actions. Or in other words, Android's memory management is much more advanced than we all think we are.
Root How to Root Insignia Flex
I'm attempting this on an NS-P11A8100. I'm *sort of* making progress. I get the unit to show in Device Manager, but it shows as a battery only, and no ability to transfer data.
I'm also using some of the instructions on http://grieve-smith.com/blog/2015/08/how-to-connect-an-insignia-ns-15at10-to-adb-on-windows/
Part of the problem, I think, is that this device doesn't give access to settings to enable USB data xfer. It's a really odd cookie. So I'm caught in a circle where I want to root, but need to transfer data to do so, but I can't because I'm not rooted, so I can't transfer data, which I could do if I were rooted...
*sigh*
Listed as a “Lurker!” That's funny.
Filter
