New App: Rare Bundles (Version 1.0)
- By App Update
- Apps & Games
- 0 Replies
EXTRA INFO
- Rating: 0
- Installs: 100,000+
- Download Size: 4.9M
- Version: 1.0
I did that and got a lot of links. Some don't list my model, others seem to imply that it depends on the SIM card.[snip]
I'd suggest the simplest solution is probably to just type "<model name> volte" into your favourite search engine.
[snip
Correct! Will post the full pic next time I'm on the computer.Darth Vader's Helmet.
Yeah, I don't think it's an option you 'turn on' but rather the need to have some kind of driver/firmware installed in order for some external devices to work. In this instance it could be a driver could be required for the mouse or the OTG adapter/cable, or both. And it's matter where with Android something like a device driver is added via an app. So unless this is done back when the screen was working, that 'might' be part of the problem since testing this requires a Pixel 2 XL, and that specific brand of mouse and that specific brand of an OTG adapter/cable.I tried this setup on another working Pixel 2 and it didn't power up either. I'm assuming something needs to be assigned in which case i'm out of luck. Can anyone confirm what needs to be turned on?
Maybe something went funky in the software? Just a guess. Have you tried restarting the device?
FWIW I have a Galaxy Note20 Ultra with latest updates, and all 3 points raised are still working as they should on my phone.
I like to buy a celeron laptop...
https://www.amazon.com/PiPo-W14-8GB-Ram-128GB/dp/B08R29G3R9
can I run Android Studio with it? is it possible? thanks...
