Holiday feast 2021
- By ozonetrooper
- Food and Beverage
- 13 Replies
I have a food hangover this morning !
Someday I will...But for now I stick with WD OSVLC Media Player. Have a try.
https://youtube.com/shorts/V1vi5VBfQAM?feature=share this is the videoI can't see the video still, but as everyone says the problem started when you broke the screen, the only solution is to fix the screen. And the only way of fixing it is to replace it with a new one. You may wish there was a cheaper solution, but I'm afraid there is not.
I have installed droidwebcam client on android 5.5 and Windows 7 about month
ago. Finally I achieved to see the picture from my samsung galaxy smartphone on
PC droid client as well as in the Skype settings video camera. As my mobile internet
speed was slow I was unable to test the video. This week I switched to LTE mobile
internet so it is enough to stream some video. I needed to have Google
Meet talk so I decided to check it beforehand using video testing (GM preview)
in browser on this service.
Indeed after some incorrect attempts to get video (picture) on PC screen and GM preview,
I found correct way, I then stumbled upon permanent video disappearing and PC DroidCamApp crash after several seconds of rendering in Google Meet video testing screen. The error in app events logs - show the crashing module ntdll.dll (C:\Windows\SYSTEM32\ntdll.dll) for
DroidCamApp.exe.
It happens permanently in last two days. I tried to uninstall and reinstall new ntdll,
but uninstalling and installing in cmd is not possible, but manual replacement
did not changed nothing in this crash appearing, as well as new DroidCamApp PC
client installation and re-installation the same but latest 6.5.2 version.
I also changed app adb folder with latest adb.exe, AdbWinApi.dll, AdbWinUsbApi.dll,
but no changes.
What could be the reason? What I can do? Maybe it is deeply connected with video
card obsolete issues in ntdll that is not resolvable.
I used such steps to set this video phone-pc interaction:
1) Connect Phone to PC;
2) Enable USB debugging in Android Developers Menu;
3) Open Droidapp on Android;
4) Open DroidApp PC client;
5) Setting usb option on PC client
6) Starting video;
After appearing this video could disappearing
for some time on PC client, then appear
again. But after launching Google Meet test
video, it hangs after several seconds and
cover lower part in grey of video screen.
And I cannot capture video for test.
I suppose that direct video connection in GM
in this way would be also intermittent
and closed quickly as I tested it also
for Zoom two days ago so the video screen
was also partly covered by grey and video stopped
there.
I tried first this official guide -Connect via USB (Android) -https://www.dev47apps.com/droidcam/connect/
where there is instruction to open pc client at first,
but it was more error-prone, with messages that
"check if app is ready and open" and "if the same ip"
as it also happened in another cases. And I noted that
"Allow USB Debugging" almost not appearing in case
I open android app first and randomly when I launch
PC client first, indeed month ago it happened to be.
But it seem the issue is not in the order of connecting
but in swift video disruption in Google Meet at least
and feeble video in PC client and subsequent crash
(due ntdll.dll) as it could disappear and reappear even until it.
What can I do and what could be the reason of it?
Greater then 1tb already exists for awhile now, prior they were in Asian international markets just swap over to China or India eBay and aliviaba etc. Takes awhile but they're official brands and non name brand versions too at UT own risk
Unless I missed something, the Verizon link above simply tells me how to turn on Location using Settings. I want to turn it on with a Then clause in a Bixby routine.
