android 11 app icon question
The short answer is "don't long press on the icon, just touch it".
This is the "App shortcuts" feature. If you just touch the icon it will open the app, but if you press and hold it offers shortcuts to whatever actions the app developer thinks people are most likely to want. The feature itself has been around for about 5 years, but more apps are using it now. Google do not provide any way of disabling it. You could try giving feedback to the WhatsApp developers, telling them what you don't like about it, and seeing whether anything happens. That's an extreme long shot, but probably has marginally more chance of getting a response than complaining to Google.
Tracfone to Simple Mobile
TRACFONE Owned Brands
1) TRACFONE
2) NET10 WIRELESS
3) Straight Talk Wireless
4) SIMPLE Mobile
5) telcel
6) SafeLink WIRELESS
7) pageplus nationwide prepaid cellular
8) Total Wireless
All of these wireless plans/brands will work on any TRACFONE branded locked phone and any unlocked GSM phone.
TRACFONE is the top of the top and all the other brands are underneath it, so all brands under TRACFONE will work in TRACFONE branded locked phones, but TRACFONE will not work in the ones under it.
Here is a few examples:
1) A SIMPLE Mobile Service SIM card will work in a TRACFONE branded phone, BUT the TRACFONE Service SIM card will not work in a SIMPLE Mobile branded phone... even though they are technically owned by the same company.
2) A NET10 Service SIM card will work in a TRACFONE branded phone, BUT the TRACFONE Service SIM card will not work in a NET10 branded phone... even though they are technically owned by the same company.
3) A NET10 Service SIM card will NOT work in a SIMPLE Mobile branded phone, NEITHER will a SIMPLE Mobile Service SIM card work in a NET10 branded phone... even though they are technically owned by the same company.
You can use a TRACFONE/NET10 SIM Card Kit to activate service on the other brands like SIMPLE Mobile, but it will be linked to SIMPLE Mobile and can only be used in a SIMPLE Mobile branded phone, or a TRACFONE branded phone, or any unlocked GSM phone.
Example:
If you use a TRACFONE/NET10 SIM Card Kit to activate service on Straight Talk, then that SIM card will only work in a Straight Talk branded phone, or a TRACFONE branded phone, or any unlocked GSM phone. It will not work in a SIMPLE Mobile branded locked phone.
Hope this helps clear up any questions you have about your TRACFONE and TRACFONE related services and devices.
Sources: I've already done all the leg work and tested each one individually. Accurate as of 2019
Ok, how about can I use an activated Simple Mobile SIM in a Total Wireless iPhone? I'm asking because I want to get my son an iphone and Total has an insanely low price on an XR.
DND app Night Keeper
Hey,
Prior to android 10 I used Night Keeper for years and there was some change in android 10. Its some special setting which needs to be changed in order for the apps white list to put calls through. Anyways, this app is "no longer useful beyond android 9+." That being said I stumbled across the magical setting a couple months ago but I had to do a reset of the phone and cant remember what the setting was. I had it working flawlessly for months so I know its possible. I remember losing my mind last time too but then randomly came across some post which listed the settings I needed to change. There is a setting called DND access but you can only select whatever apps it lists, I cant force night keeper. I dont think thats the issue because it does turn on DND, more on that below.
Summary of what the app does in case people arent familiar;
DND app but it lets you create profiles. So I have a sleep one which turns off BT and all notifications except calls from specific contacts, it turns on android DND but then SHOULD override something when specific callers call. It is not recognizing the contacts which are in my list so their calls are not put through. I have a profile called Text & Phone, its listed as priority mode rather than silent and full ringer. So all calls and then whatever apps I do want notifications for (messaging, etc) so in other words no email (still synced though) and only actually important notifications. In order to get those notifications you have to go into the app notifications settings and allow override DND. It has to be some permission to allow it to read contacts or something since the app works other than call filtering. ANY IDEAS??? I havnt been able to find a similar app which does what I need.
Gitlab CI/CD Build Issue
Building an android project using gitlab ci/cd.
There is no problem in the build process, but after the build is completed, the java.exe process is not terminated, so the build stage does not move on to the next stage.
My solution is terminate java.exe process directly.
Is there any way to solve this problem?
android studio : 3.6.3
gradle : 5.6.4
openjdk : 11.0.2.0
thanks
Need help identifying this heart-shaped app on Android
It would help if you posted the icon.
But you should be aware that there are a huge number of apps, as well as many different types of apps, that use heart icons. So unless it's a fairly well-known one or distinctive enough for a reverse image search to work there is a good chance that nobody will be able to recognise it. Usually the best way is to ask the other person (since most of these queries concern screenshots from someone else's phone, even more so when heart-shaped icons are involved!). But if you post it we'll give it a go.
Any Decent Small Android Phone?
Assuming that there is any way of removing the blacklist: I'm pretty sure most UK carriers don't even let you pay off the previous person's bill to clear it.
"Size of an iPhone Mini" is tricky, since if the 64mm width is important you get very few options. Here is a list from GSMArena's phone finder, where my search criteria were simply "year > 2018, Android, bar form-factor (to eliminate watches from the results), width < 66mm". There aren't many, and the only half-decent ones are old (which is important because you have to consider battery condition: both 3 years use and sitting in a box for 3 years will degrade that, though being used for 3 years is likely to be worse unless you have an extremely battery health conscious user).
Relaxing the width restriction to 68mm doubles the number of results, though most of them are still lower-end than the Pixel 3. The Pixel 3 itself appear when you loosen the width limit to 70mm, but is also a cm taller than the iPhone 12 Mini: if you want to restrict the height as well you will lose most of the extras you gain by being more tolerant of the width.
I tend to not care about resale value because by the time I replace a phone I don't expect it to have any significant resale value left, no matter who made it. But if you are serious about size-matching the iPhone Mini then you'll be looking at either old or second-hand anyway: when I asked for Android phones of similar height and width to the iPhone 12 Mini released in the last 2 years I got only 3 results, and all 3 are junk that falls far short of the Pixel 3.
Note that I'm writing as someone who has no interest in large phones, and would regard the iPhone 12 Mini size as perfect (being able to use it one-handed on the go matters to me, watching videos on a phone does not). But there simply aren't any recent decent Android options as small as that.
[Scam alert] How people trust this app?
The only Play Store app I instinctively trust is Rectanal, the haemorrhoid detection app for which you must allow all permissions and sharing.
You must take 10 shots in succession from 5 feet (bent over).
Slightly troubling that it doesn't confirm yay or nay, but rather scores you out of 10.
Best thing is apparently my app username has become extremely popular on some parts of the interweb. For an aging man that's unexpectedly flattering. ;) :cool:
[Free][Game] Jonin Adventure - Run and Shoot Adventure World
Are you ready to use your run and jump side scroller skills to overcome the challenges of obstacle course? How about using your island survival experience to kill enemies, collect bounties and become the best player? With this epic escape adventure game, you get to experience the best of platform runner action. With the smooth super adventure runner controls and immersive gaming action, this epic run and jump game is here to offer you the best side scroller experience. Kill your enemies, jump or duck to evade the deadly obstacles, collect coins and gold, unlock exciting new powerups and play for as long as you like in this endless obstacle course game.
Play Jonin Adventure – Run and Shoot Adventure World now!
Are you ready to challenge your escape adventure skills? Step foot into the world of island survival and use your epic platform runner skills to challenge your survival expertise. What’s even more exciting is that you get to play in a unique island environment where you must kill the enemies, dodge the obstacles, collect rewards and continue moving forward to the end of every level without stopping.
Epic Island Survival Action
Tune into your island survival mode and follow your instincts to run and jump using the side scroller button. Make sure that you do not touch anything which you are not supposed to touch and act quickly to destroy your enemies. You will face hordes of enemies coming at you from the opposite direction, so you must tap on your screen to shoot bullets and kill them as quickly as possible.
Run and Jump in Side Scroller
Featuring smooth and easy tapping controls, this platform runner game is designed to be your perfect pastime. Simply tap on the side scroller control to run and jump and move forward in escape adventure. Move as swiftly and carefully as you can to dodge any harm and save yourself from getting killed by the enemies.
Collect Power ups and Rewards
Maintain an impressive run and jump streak to collect super adventure runner rewards and unlock new power-ups. From consistent flying and immunity against enemies to magnetic qualities and super adventure runner multipliers, this side scroller game offers an exceptional gaming experience. Collect rewards and increase your score.
- Simple and easy to play super adventure runner UI/UX
- Immersive platform runner action with smooth side scroller controls
-; Run and jump to overcome the obstacle course challenges efficiently
- Collect escape adventure rewards and unlock island survival powerups
- Play platform runner for as long as you like and set a new score record
- Unlock new power-ups and new characters to play island survival
Download and play Jonin Adventure and Run and Shoot Adventure World today!
Google Play: https://play.google.com/store/apps/details?id=com.JoninAdventure.Game
Gameplay Video:
App Info
Current Version: 1.0
Requires Android: 4.1 and up
Content Rating: Rated for 3+
Filter
