Only me!
what is a Chinese unicorn? is it really a unicorn? or a fish, like an Asian arrowana?
It's "uni" as in united. In Chinese it's 中国联通, which literally means China United Telecommunications.
Tell us about it @mikedt. You've used lots of operating systems and sim cards. A more traveled man than I've ever met. How many sim cards does it take to travel halfway around the world?
netflix? not sure what the title of your thread means in conjunction with netflix.Please, someone can explain me the application ?
I created a channel for your app. Good luck!!
https://androidforums.com/apps/random-number-generator-randomizer.19566/
no idea, could be that sim card you have. maybe try replacing it?..To restore internet connection i have to enter into flight mode and then stop it (or restart etc..)
My phone is Redmi, android 10.
Im using 2 sims. the secondary is a prepaid without outgoing calls and data.
The internet is defined to use only first sim.
if i eject the secondary sim the problem stops. if i use another secondar sims from a friend, the problem stops again.
What can cause this issue?
